Best Case Fans?
DiegoBoricua
75
Hello everyone,
I'm about to start a new build in the Phanteks P400. As you all know, modern case designs are very nice and sleek, but with that comes a high lack of airflow.
What are the best options when it comes to fans that give the best bang per buck? The fans do not need to have RGB but it's always a plus (though probably wouldn't fit under budget). I also would prefer if the fan is white or has a white accent. The fans should be 120mm and maybe have a 140mm option.
Thanks.
Thanks
Ok, sounds good thanks! Especaially when they're half the price.
By the way, would you recommend I get 3 as intakes and 3 as exhaust, or just 2 as exhaust? (i.e. neutral vs positive pressure) Or the other option would I guess would be to get the six but tone down the exhaust
3 intake and 2 exhaust. For dust you want more air comming in than out.
IF however you still see alot of dust build-up happening fast, you should still tone down the exhaust fans since the P400 is a bit restrictive in the front.
Just be alittle carefull about tuning down the exhaust fan close to the MOSFEt on the motherboard IF you are overclocking, since they need cooling.
