[SOLVED] Best case for around $60
how is the airflow?
It should be good as the front appears to be mesh.
https://cougargaming.com/products/cases2/mx330_g/
It does come with the one fan in the rear for exhaust so it probably wouldn't hurt to add a fan or two to the front as intake.
Thanks. If i do this one i need to find case fans for under 10. DO you think one is enough? The case comes with one
Try it first with the stock exhaust fan and if temps get a bit too high then I'd add 1-2 into the front as intake but try it out first. Considering the front and top is mesh and from looking at your part list I don't think you'll have issues unless you have some crazy high ambient temp.
