Question Best case for cable management/airflow under $100
Is that out of the box airflow, or after adding a couple of fans? Some models do have subpar performance before adding some fans... I'll list it if that turns out to be the issue.
Fractal Design Meshify C: needs a couple more fans to maximize the potential of the mesh panel.
Corsair iCUE 220T RGB Airflow: you'll have to reconsider if you're planning to use the larger liquid coolers - 280mm or greater, in here.
Phanteks P400A
NZXT H500 series: specialized in negative pressure for air cooled setups. There is a limit to what it can handle on air, namely the high power consuming cpus and gpus, though the solution is simply to liquid cool the one with greater power consumption.
Cougar MX330 and variants: needs a few fans.
Fractal Design Focus G: needs a couple fans.
Reactions: RodroX
Phanteks P400A
Out of the box airflow is what I’m looking for
In that case...
Phanteks P400A
In that case...
Phanteks P400A
I was actually looking at the Corsair 275r since it’s on amazon and back in stock, looks great for airflow and cable management as well since a lot of people have been saying about it, even supports 240/360mm rads
The reason I didn't include that in my list is because the review disagrees with those people on the cable management front: https://www.tomshardware.com/reviews/corsair-275r-airflow
It's made easier through:
-not having any HDDs
-having a modular power supply
Or were you referring to the non-Airflow version?
https://www.tomshardware.com/reviews/corsair-carbide-275r-tempered-glass-case,5502.html
Non-airflow, wait is there a difference in cable management between the regular and airflow version?
The HDD cage is actually removable - assuming you don't use HDD drives... but if you actually do need it, you're going to have to get creative with placement...
what’s wrong with non-modular LSU’s in the case?
I'll assume you mean Psus... but the problem is THIS:
Granted, the Corsair HX750 is about 20mm longer than a typical ATX psu, that still doesn't amount to much.
The HX750 is a fully modular psu - and the reviewer still removed the HDD cage for easier cable management.
Semi-modular, and non-modular units are going to be even less flexible.
That sure is a lot of cables but i think I will be fine, i have a hdd slot in my own pc with a non-modular PSU, it also does look a bit wider than my psu.
