L Linnaeus Reputable Mar 8, 2014 287 0 4,780 Jun 27, 2014 #1 Looking for a mid tower case for around $130 with the best cooling.
Solution V V vixl2ds Jun 27, 2014 http://www.corsair.com/en/carbide-series-air-540-high-airflow-atx-cube-case PSU goes in one side and mobo in the windowed side... the fans are a few cm away from the mobo and gpu and blow right on top of it
V vixl2ds Honorable Dec 26, 2013 470 0 10,860 Jun 27, 2014 Solution #2 http://www.corsair.com/en/carbide-series-air-540-high-airflow-atx-cube-case PSU goes in one side and mobo in the windowed side... the fans are a few cm away from the mobo and gpu and blow right on top of it Upvote 0 Downvote Solution
mickypheonix Honorable Mar 9, 2014 4,051 1 10,960 Jun 27, 2014 #3 Hi Linnaeus a couple of great choices for high airflow , good build quality and cable management http://www.newegg.com/Product/Product.aspx?Item=N82E16811119257&cm_re=coolermaster_hafx-_-11-119-257-_-Product http://www.newegg.com/Product/Product.aspx?Item=N82E16811119265&cm_re=coolermaster_hafx-_-11-119-265-_-Product Upvote 0 Downvote
