G Guest Guest May 4, 2013 #1 Hi there, I would like to know what case you think is the best for LAN parties. I am not bothered about the form factor (ATX, Mini ITX) but it should cost £50 or less. I hope you can help!
tiny voices Titan Sep 6, 2012 34,175 5 99,965 May 4, 2013 #2 http://www.newegg.com/Product/Product.aspx?Item=N82E16811146065 Have always thought that case was awesome. Has a hndle and stuff for easy carrying. It is mATX so you ill have to use an mATX motherboard. Upvote 0 Downvote
manofchalk Glorious May 11, 2012 12,913 6 48,960 May 4, 2013 #3 I cant find it on any of the UK sites I know, but the Bitfenix Prodigy is a pretty amazing ITX case that I think will suite your needs. Upvote 0 Downvote
