Best case for me and airflow
RHurbungs
52
Hello,
I am planning to upgrade my computer case Cooler Master Elite 342. I want one with the PSU at the bottom. Now I am also having problems with airflow in my computer because I do not have any fans and my computer is in a cabinet. So I am planning to buy fans but I also want to upgrade the case which cases do you guys recommend? I do not really care about brand but I do not want to pay much I think my max is €100 I do want to have a lot of fan connections ( front, side, back and above. Also because my computer is in a cabinet the case height and length is important. heightmax = 35cm (14") lengthmax = 43cm(17")
I was looking at the thermaltake V21 because you can place the panels everywhere
Just the height and depth is won't fit the dimensions I gave are really the max.
