Best Case for Minimum Dust
m7mddxb
27
Hey guys !
i have a Haf 932 which is just bad now imo, because it collects dusts easily! i need to know any suggestions from you guys that what case should i go for ? i was thinking about the Corsair650D or the C70 , and was wondering if there are any better Cases out there.
these are the main features i need for the case:
-Dust filters
-DualFan For h100 or so...
-simple and easy
-Better airflow
You won't get better airflow and any of those options if you want a dustless environment. Or rather, and upgrade to the HAF 932. This means the environment you are in is dusty, just blow out your system every few months with a can of compressed air.
i have define r3 there is an r4 now it have dust filters an its silent too!
just make sure u got positive airflow otherwise you suck air with dust trough holes where there are no filters.
What about the Storm Trooper/Stryker. It has a lot of features and dust filters. Full tower and the main difference between those is the support of 2 120 mm fans in the Storm Trooper, and the stryker has a big side window (So you may loose some airflow)
It can't fit H100 in push/pull because of the handle in the top, but a single push or pull can be done easily. But in that case you can do custom watercooling.
The airflow is not better than the HAF 932 but still is good.
Storm Stryker:
http://www.amazon.com/CM-Storm-Stryker-Computer-SGC-5000W-KWN1/dp/B008O2HOI2/ref=sr_1_2?s=electronics&ie=UTF8&qid=1356813391&sr=1-2&keywords=storm+trooper+case
Storm Trooper:
http://www.amazon.com/CM-Storm-Trooper-Computer-SGC-5000-KKN1/dp/B005P7XSV6/ref=sr_1_1?s=electronics&ie=UTF8&qid=1356813391&sr=1-1&keywords=storm+trooper+case
If you can have your MB control the fans, slower fan speeds = less air = less dust. As long as you can do all this without too much heat, it keeps lots of dust out.
Filters help lots, but can cut air flow and clog up fast as well(so you have to clean them.).
The Antec 900 is a dust magnet too, but again, its all because it moves so much air.
Phantom 410/820
Cm storm scout
i do have a Haf 932 , and the usb slots in front only one works because the metal are not there.. dunno how to explain it to you.. bu yeah , so thats why i was thinking of changing
