Best case for my build?
GrimnirBuilder
17
There a lots out there but I can narrow down quite a fair bit because I want
1. White case
2. Big as possible for under £100
3. Large window on the side, so rule out any that have no window or small window
4. 1150 motherboard I will be getting ATX size
5. I want to liquid cool the CPU and then have several fans to cool the inside as much as possible
6. I plan on having fans where the drive bays are because I will only be having a SSD and may even go for one of the new ones that slot into the motherboard, if not too expensive
1st Choice:
NZXT H440
http://www.amazon.co.uk/NZXT-H440-Tower-Window-Quiet/dp/B00HVZIXDI/ref=sr_1_2?ie=UTF8&qid=1444663575&sr=8-2&keywords=nzxt+h440
2nd Choice:
NZXT Phantom 530...
1st Choice:
NZXT H440
2nd Choice:
NZXT Phantom 530
http://www.amazon.co.uk/NZXT-Phantom-White-E-ATX-Chassis/dp/B00D7OVWFS/ref=sr_1_1?ie=UTF8&qid=1444663618&sr=8-1&keywords=nzxt+phantom+530
Case: Phanteks Enthoo Pro ATX Full Tower Case (£83.50 @ CCL Computers)
Total: £83.50
Generated by PCPartPicker 2015-10-12 16:30 BST+0100
Phantom is one of those on my list. I actually got a youtube review paused since I join this forum ~hour ago 😛
Looks good but the window is not as big as wanted
Last case I got was Antec something, forget the number. It was ~4 years ago, big and very bloody heavy. I liked it but I said to myself, next case I want a completely transparent window. No fan on the inside or anything like that, just like a window of my house
