Best case for my hardware?
Hyungbae
9
So I upgraded my computer a couple of days ago. It works really nicely IMO.
Here is my computer I upgraded from: Gateway
Anywho, getting to the actual topic, I am wanting a new case that is somewhat less spacey, but can hold 2 DVD drives. Also a case that has a very nice ventilation. It should fit a mATX board well, and if I were to upgrade a GPU (which will be soon), I should have clearance on the case to fit the GPU.
CPU: i7-4790k @ 4.00ghz LGA1150
RAM: Corsair Vengeance 8GB 1600mhz
GPU: EVGA GTX750TI SC
HDD: 7200RPM 1TB WD
Motherboard: Gigabyte Gaming 5 mATX
PSU: EVGA 430 +80W
I am soon upgrading my GPU to MSI GTX 960 2G
Case: Corsair SPEC-03 Red ATX Mid Tower Case ($43.99 @ Newegg)
Total: $43.99
Generated by PCPartPicker 2015-02-22 22:09 EST-0500
It's a nice case (got one under my desk) but it's not microATX so it's definitely not as compact as you could go.
The case I use for my main machine, although capable of taking a full ATX board, is one of the smallest full ATX cases you can buy. It's got fantastic airflow, all aluminium design but the unassuming look isn't to everyone's taste.
http://www.lian-li.com/en/dt_portfolio/pc-a05fn/
I am also quite a big fan of the Aerocool dead silence, if you want to go for a cube case:
http://www.aerocool.us/ds/ds_black.html
Then you also have the Silverstone Tamjin for a more traditional approach:
http://www.silverstonetek.com/product.php?pid=303&area=en
**Edit, just re-read your post. You need two DVD drives so the Aerocool is no good. Only one DVD slot.
