Ajwork
83
I need a small-to-mid form factor case that supports almost exclusively mATX motherboards and can fit up to two graphics cards. It'd be nice if it could support a Corsair H60, as well. If not, a recommended CPU fan (other than a Noctua NH-L12, which I'm already considering) would be appreciated as well. External drive spaces are pseudo-irrelevant, though I'd appreciate at least one or two 5.25" external drives and at least one or two 3.5" internal drives. External 3.5" drives would be great, but aren't necessary. An internal 2.5" drive bay would also be acceptable. I really don't want the case to be significantly larger than the motherboard, even though it's carrying two video cards.
If it means anything, the motherboard (I already own):
http://www.msi.com/product/mb/890GXM-G65.html
Corsair H60:
http://www.corsair.com/hydro-series-h60-cpu-cooler.html
Ajwork
83
It's a mini-itx case, but it's a really nice one that I'll consider for an ITX build.
http://www.bitfenix.com/global/en/products/chassis/prodigy
So, I think I have a good idea of what kind of case I want; out of these cases, which one looks best to you?
Fractal Design's Arc Mini
http://www.fractal-design.com/?view=product&prod=59
NZXT's Vulcan
http://www.nzxt.com/new/products/crafted_series/vulcan
Thermaltake's Lanbox Lite
http://thermaltakeusa.com/Product.aspx?C=1320&ID=1430
Thermaltake's Armor
http://thermaltakeusa.com/Product.aspx?C=1466&ID=1989
I personally favor the Vulcan, but the Arc Mini might have better options in terms of expand-ability (i.e. H60).
