[SOLVED] Best Case for Noctua NH-D15 SE-AM4
luizmartini
20
Hello, i need recommendation of cases for me use my noctua nh-d15 se-am4
Actually, i have the view27 and its not supports, the airflow from this case is very bad.
I want one good for airflow and can use this noctua. I'm thinking to buy coolermaster H500, have other better one?
The Meshify cases don't have here on Brazil here i live, so i need other option. What you guys think about the H500 from coolermaster? Have one better? Which?
Thanks!
One friend said to me is much better to buy the NZXT H700 or Deepcool Macube 550.
For the first one: not really? The H700 is NZXT's solution to the somewhat lacking airflow in the H500: brute force by adding more fans...
The 2nd one is actually pretty terrible on airflow from what I've seen.
Because the H500 CoolerMaster the fans from front not have good airflow and have much plastic...
After they got flamed for that terrible acrylic front panel idea, Cooler Master started including an alternate mesh panel in the H500 packaging.
The H500 (with the mesh front) should work well.
https://www.gamersnexus.net/hwreviews/3334-cooler-master-h500-case-review-recommended
Any decent mesh front case with decent case fans (2 or 3 front intake, 1 or 2 rear exhaust and 1 or 2 top exhaust) should work well for you.
I personally have a Rosewill Rise Glow full tower case (with a mesh front) and I love it.
It has 3 120 mm front fans a 120 mm and an 80 mm rear and a 140 mm top fan and it has Great airflow.
What you think?
I bought the H500P Mesh, good choice?
