Best Case under $100 USD For Watercooling?
Agemt69
56
I'm looking for a good watercooling case for under $100, I would like for it to have a big glass window. Cooling probably won't be a problem for me since I am not planning on overclocking (yeah i know, watercooling and not overclocking???? I'm doing it for silence and for A E S T H E T I C, since the PC will be in my room)
Color really does not matter since I was planning on painting my GPU backplate and parts of the cooler so I can paint the case too I guess. I would also like for it to have a GPU shroud since I do not want to make one myself
The Define S is a little wider than many mid-tower cases. However, it has two things that not many other cases have, dedicated mounts for reservoirs beside the mobo tray, and dedicated mounts for a pump on the bottom, underneath the reservoir mounts.
