Best choice for hub upgrade
bjacobb
I have been using a 10/100 ethernet connection for a few years for my lan parties, and I now have to upgrade to a hub with more connections. For a the best gaming experience, what is the best type of hub? Should I switch over to Firewire, or stick with ethernet?
how many ports do you need? if you need more than 8 you really should get a switch instead of a hub. without going into too much detail i will just say they are "faster".
wpdclan.com cs game server - 64.246.52.144:27015
now featuring (optional) cheating death!
Why get a hub in the first place. If you gonna buy something don't waste your money on a hub because a switch has much better performance per port and is more "managed" than a hub.
Barton 2500+@2090 MHz , MSI K7N2 Delta-L, Corsair PC2700 512 MB, Gigabyte Radeon 9600XT 128 MB, Maxtor 120GB 7200rpm 8MB Cache, X Dreamer Turbo Case 350w
<A HREF="http://www.cdw.com/shop/products/default.aspx?EDC=627859" target="_new">These</A> are NICE!!!
May be a bit of overkill for you though... :smile:
I personally like Linksys. They are made by Cisco. Best Buy has two Linksys 16 port switches on their <A HREF="http://www.bestbuy.com/site/olspage.jsp?id=cat01033&type=category&parentCatID=false&_requestid=8044" target="_new">website</A>. One for $129, one for $99. <A HREF="http://www.newegg.com" target="_new">Newegg</A> also has a bunch. Searched for Linksys 16 port. You will have to compare them, but I saw two for $77 or so...
Another option would be to get another smaller one (8 port) and link the two together...
<font color=blue>GO CUBS GO!</font color=blue>
<font color=red>GO CUBS GO!</font color=red>
I'd rather be at Wrigley Field!
