Best clear case?
anceintsz
148
What is the best fully-clear case for a build? Something like Sunbeam AC-9B-HUVB but I tried looking for it and it's out of stock everywhere. Does anyone know of a case like it?
You don't need a cooler, Ryzen comes with a good stock cooler. Ram too slow, and you should get dual channel. 128 gb ssd too small for storage. No need for sound card, motherboard has it. Why 900p monitor? 1050 ti can do 1080p just fine. Pcie wifi is better than USB. What is your major usage? Total budget of the rig including everything?
I didn't know all that!! Thank you for looking it over. I won't be needing that much space for much I have a 1tb hard drive already the SSD is just for boot and maybe some games. My major usage? I don't understand that question. If you mean something like gaming then yes gaming. I had a budget but right now I'm flexible with how much I can spend I want just medium grade graphics and I want to keep the ryzen 1200. The 900p monitor. I don't need 1080p I am fine with 900p. Also I don't see any wifi specs on the mobo so I'm sticking with seperate wifi.
Case: https://www.ebay.com/i/322602876680?chn=ps&var=511593443481
CPU: AMD - Ryzen 3 1300X 3.5GHz Quad-Core Processor ($128.69 @ OutletPC)
Motherboard: MSI - B350 TOMAHAWK ATX AM4 Motherboard ($65.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-3200 Memory ($108.99 @ Newegg)
Storage: ADATA - Premier Pro SP600 128GB 2.5" Solid State Drive ($47.99 @ Amazon)
Video Card: MSI - GeForce GTX 1050 Ti 4GB GAMING X 4G Video Card ($159.89 @ OutletPC)
Power Supply: Corsair - TXM Gold 550W 80+ Gold Certified Semi-Modular ATX Power Supply ($54.99 @ Newegg)
Optical Drive: Samsung - SH-222AL/BSBS DVD/CD Writer ($19.89 @ OutletPC)
Wireless Network Adapter: Gigabyte - GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter ($35.89 @ OutletPC)
Monitor: LG - 23MP57HQ-P 23.0" 1920x1080 60Hz Monitor ($99.99 @ Newegg)
Total: $722.30
Generated by PCPartPicker 2018-01-02 21:36 EST-0500
Thank you I'm still keeping my build but I'll get that case though! Thanks!
