Best continuous recording NVR for 5Ghz network?
fcar1999ta
182
Looking for recommendations for a wireless NVR security camera system that will work on a 5Ghz wireless network. I need continuous recording and at least 2K resolution. I might settle for 1080p, but I doubt it.
Wireless is a bad network choice for critical data like security cameras.
If you believe you MUST use wireless, get a WIFI bridge and a wired NVR.
I know, but it is for my house and just for now, until I can afford to completely revamp the whole house and install WAPs and POE cameras.
Have you looked in to the Reolink line?
I have 3x of their wired cams.
But, if I were to go wireless, I would start with some of those.
For me though....security and wireless do NOT go together.
