best cooler for 3570k
horus896
18
i would like to have your advice on which cooler to buy.. i'm new to overclocking and i need the best cooling performance air cooling budget cooler.
how much do you want to spend? are you opposed to closed or open loop water cooling? Do you already have your system and RAM? If you have RAM with the big heatspreaders on them, a lot of those above ones won't fit as the heatsink is too big and you couldn't use it unless you have low profile RAM.
i didn't get my system yet, i'll get Kingston HyperX Blu 8GB DDR3 1600MHz CL10 1.5V.. i don't want water cooling, air cooling only.. i'll probably want to get it to 4.5ghz and i want something that can keep it at max 60 degrees while gaming, and i live in egypt it's pretty hot here.
