best cooler for Phenom II X4 965
D
The Hyper 212 Evo is about the best bang for your buck cooler. It will be fine for your Phenom II. Push/pull just involves mounting a fan on the back of the cooler blowing through ( stock set up ) and a fan on the front pulling. The dual fan configuration will lower temps maybe a few degrees. Most Phenom II chips top out about 4Ghz due to the limits of the architecture. A Hyper 212Evo with a single fan should get your CPU to 4 Ghz with no problems. Remember to keep max load temps under 62C.
That's as good as it gets in that price range.
Push / Pull , is when , on one side of a heatsink or radiator you have a fan pushing air towards the heatsink, and on the other side, you have a fan connected pulling that air away from the heatsink.
In practice, push/pull isn't very effective. Some people seem to think it works wonders but it really doesn't, it's effects are minor at best. I don't recommend it .
62 is max before degradation but 55C is max before stability issues, running high overclock on 57C might cause cpu to bug out
