Aamir Ahamed :
Whats wrong with the CM Hyper 212 Evo?!
It's not that there's anything actually wrong with it aside from being an older cooler. It may not appear in a 'best' list unless the list is based on price brackets just because it's a budget cooler and can't compete with nh-d14, dark rock pro 3, cryorig r1.
The cryorig h7 is basically an updated 212 evo. Even though it's from a different company it cools a couple degrees cooler, just a little quieter and it has an updated design that makes it more favorable for intel builds. Maybe amd as well though I'm not as familiar with the spacing between the cpu socket/cooler mounts and the ram slots. It uses an offset heatpipe design so there's 0 ram conflict on intel platforms like lga1155, 1150, 1151.
The fan on the 212 evo presses against ram in the slot closest to the cpu unless using low profile ram or moving the fan up (which makes the overall cooler height taller). The h7 is also shorter which can mean the difference between fitting or not fitting in more narrow cases.
Prices are similar (at least in the U.S., local pricing may vary other places). The 212 evo is only $5 cheaper, for $5 more the h7 offers a slightly better cooler all the way around in both performance and clearance. I can't speak to the fan that ships with the h7, the one that ships with the 212 evo is a pretty mediocre quality fan. Cheap plastic, sleeve bearing, the fan died in less than 2yrs. Coolermaster isn't exactly known for high end fans. I imagine the cryorig fan is better, certainly no worse.
