D
Deleted member 2798512
Guest
i have a radeon rx 5700 and ryzen 5 3600. should i buy an aio or can i ust use the 2 fans that come with the case
Yes. The Corsair H60 is a 140w dissipative capacity cooler. The CM Hyper212 Evo is also a 140w dissipative capacity cooler. It happens that they also have almost identical temp curves and do have identical max temps.I use a Corsair H60 on a 3800x and it does the jog just fine. Goes to show that a 120 AIO is equivalent to a good air cooler. The 3600 is a much lower TDP cpu and a 240 AIO is overkill for it. Upside is how silent it would be.
