Best Cooling for my Cpu
Zorgax
9
I just built myself a new pc and am thinking of upgrading the cooler to better over clock my Cpu. Currently I have an i7-5820k and a Cooler Master Hyper 212 EVO. My case is a Corsair 750D. I am probably not going to do a custom water loop so I have been looking at either a better air cooler or a liquid cpu cooler. Does this upgrade make sense to do? I was thinking either a corsair h110 or the Noctua NH-D15. Which one will deliver tye best performance (cost is less of an issue), neither potentially? I also have a friend willing to buy my old cooler if I replace it.
Another thing for to consider is whether I should spend this money on a better video card or cooling. I have a gtx 580 right now so it might be better to buy something more powerful instead.
Alastair smith
87
18
Well, you should upgrade your CPU cooler first, and the one which I recommend is Corsair H110i GTX. And the reason for this is you can't upgrade to a good GPU with the amount of money for good AIO CPU coolers.
Similar threads
