I have about $75 I can put toward cooling. I always use stock CPU fan, but I think I need an upgrade.
I had one computer running prime95 (on Linux, no X running), and it said something like:
CPU0... threshold...
I think it was about tempurature 🙁
Now I have a six-core AMD, integrated graphics (and sound), 8GB DDR3 RAM.
I happened to check temperature. From "sensors" on the command line on Linux Mint (lmsensors or something):
atk0110-acpi-0
Adapter: ACPI interface
Vcore Voltage: +1.37 V (min = +0.80 V, max = +1.60 V)
+3.3V Voltage: +3.36 V (min = +2.97 V, max = +3.63 V)
+5V Voltage: +5.10 V (min = +4.50 V, max = +5.50 V)
+12V Voltage: +12.03 V (min = +10.20 V, max = +13.80 V)
CPU Fan Speed: 3358 RPM (min = 600 RPM, max = 7200 RPM)
Chassis Fan Speed: 1753 RPM (min = 600 RPM, max = 7200 RPM)
CPU Temperature: +81.0°C (high = +60.0°C, crit = +95.0°C)
MB Temperature: +38.0°C (high = +45.0°C, crit = +75.0°C)
fam15h_power-pci-00c4
Adapter: PCI adapter
power1: 91.75 W (crit = 94.99 W)
k10temp-pci-00c3
temp1: +80.4°C (high = +70.0°C)
(crit = +83.5°C, hyst = +80.5°C)
And HDDtemp says:
/dev/sdb: WDC WD2500JS-60MHB1: 44°C
(/dev/sdb because 2TB other drive shows up as /dev/sda)
[strike]I think this is bad.[/strike] I know this is bad.
Thank you in advanced... concerned 🙁
atk0110-acpi-0
k10temp-pci-00c3
And HDDtemp says:
