Looking at both water cooling and HSF's I know that the tuniq tower is good and scythe infinity but just curious which would be the best option to go with in you good peoples opinions.
Also which temps should i be striving for idealy? My room is kinda hot most of the year ranging around 78-90 degrees F (not sure what that translates into celcius)
Also if i go with a water cooling solution, I plan on having 2 8800 GTX's in SLI, are water cooling kits upgradable to cool both my cards, or would i have to get more kits to block the GPU's also?
Thanks guys/gals!
Thanks guys/gals!
