Best cooling system for FX-8350
nugget827
Commendable
Nov 28, 2016
12
I've been having a problem with my cpu going over the max safe temps recently, even when not under load. I currently have a Asetek 510LC liquid cooling system and my application of the thermal paste was subpar because the 510LC's ring mount is very difficult to get on.
My question is:
Is a fan sufficient to cool a fx-8350? If so, would this one be good?
I think that the thermal paste will be much easier to apply if I get a fan instead of liquid cooling since it is much easier to install.
CPU: AMD FX-8350
GPU: NVIDIA GTX1070
MB: GIGABYTE 970A-D3
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler ($42.55 @ Newegg Marketplace)
Total: $42.55
Generated by PCPartPicker 2017-06-22 15:34 EDT-0400
Best budget cooler on the market.
Image from: techpowerup.com
http://www.hitechlegion.com/reviews/cooling/heatsinks/42980-cryorig-h7-universal-cpu-cooler-review?showall=&start=3
Review from hitechlegion ^
Unmatched Compatibility
Zero RAM Interference
Focusing on providing the widest range of
compatibility, the H7 utilizes an asymmetric slanted...
Do you have any ideas of cheap alternatives that are just as effective and easy to install?
Total: $42.55
heatpipe layout to move the heatsink away from the
RAM zone, Offering optimal compatibility for RAM
with tall heat spreaders on both Intel 115X and
AMD platforms.
Image from: proclockers.com
[video="https://www.youtube.com/watch?v=KrROVq0cdCY"][/video]
