best cooling system
king156
28
Hi there i have a gtx 770 and AMD 8350 4ghz. I already hacve an aftermarket cpu cooler (cooler master slim 412) and the case i bought came with 2 120mm fans however when gaming my pc gets hot so i ahev to take off the side pannel to keep it cool. when i touch the top of the cas its so hot so should i add more 120mm fans in the case. Would i see my temps drop alot say if i added 2 120mm fans maybe one on top one on bottom.
Get a program to check your temps. Is your gtx 770 a dual fan cards that feeds heat into the case. Here's a good airflow site.
http://www.techpowerup.com/forums/threads/guide-to-proper-case-airflow-design.42853/
Hi there its a tripple fan its made by gigabyte
hi ther my cpu temp is 65.
gpu is 75
yh pretty sure it is. its a cooler master slim 412 so would it make sense to add maybe 2 more 120mm fans like 2 at the top because heat rises and i could invert the fans so it sucks the air out would that work?
