S Sahil rajput Distinguished Feb 7, 2016 52 0 18,530 Mar 20, 2016 #1 hello can here any body tell that which is better cooling system is it fan or a heat sink. (for graphics card)
Solution DustinV Mar 20, 2016 ohh on graphics cards, the one with a fan on it will cool more, its a heatsink with a fan on top of it, the other one is just a heatsink with no fan
DustinV Honorable Dec 22, 2015 1,620 2 12,465 Mar 20, 2016 #2 heatsinks have fans on them, i think you mean AIO water coolers vs air heatsinks Water cooling is better, but also more expensive so it just depends on your budget, what cpu your are cooling, and if your case support water coolers Upvote 0 Downvote
S Sahil rajput Distinguished Feb 7, 2016 52 0 18,530 Mar 20, 2016 #3 no i am not asking about water coolers you can check that following links http://www.ebay.in/itm/HIS-GRAPHIC-CARD-5450-Fan-1GB-DDR3-PCI-E-3-Yr-Warranty-/151994000554?hash=item23638c64aa:g:AMwAAOSwPc9WzamB http://www.ebay.in/itm/HIS-5450-Silence-1GB-DDR3-PCI-E-DVI-HDMI-VGA-3Yr-warranty-/152009019404?hash=item236471900c:g:fAEAAOSwwPhWi5Z- both are same cards but on of them is having fan and another is having some type of heatsink I want to know weather which card will remain cool for using long 3-4hrs Upvote 0 Downvote
DustinV Honorable Dec 22, 2015 1,620 2 12,465 Mar 20, 2016 Solution #4 ohh on graphics cards, the one with a fan on it will cool more, its a heatsink with a fan on top of it, the other one is just a heatsink with no fan Upvote 0 Downvote Solution
