Best cpu and motherboard for £300
EncryptedBlade
43
I currently have an AMD FX-6300 (3.5 GHZ and Six Cores) cpu and a GIGABYTE 970A-UD3P motherboard. Im looking to upgrade to an intel cpu and motherboard but the total price must be around £300 give or a take a little bit. My current gpu is a gtx 960 msi 4gb and soon I will be upgrading to a 1060 or 1070 so the cpu and motherboard must be compatible. Thank you very much for any help, peace
Please note that i would like this build to be able to run arma 3 on 60fps.
[Two posts merged in to one by moderator]
This would be my choice:
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor (£276.00 @ Amazon UK)
Motherboard: Gigabyte GA-B150M-DS3H Micro ATX LGA1151 Motherboard (£63.54 @ Amazon UK)
Total: £339.54
Generated by PCPartPicker 2016-12-30 14:57 GMT+0000
However, I don't think any CPU can keep Arma3 pegged at 60fps, it's just a terribly coded game that runs poorly on any hardware. You'll see a nice improvement though.
This combo once overclocked will slightly outperform the i7 in Arma after overclocking but will likely perform a bit lower in newer AAA...
Total: £339.54
This combo once overclocked will slightly outperform the i7 in Arma after overclocking but will likely perform a bit lower in newer AAA games:
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor (£215.99 @ Aria PC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler (£29.98 @ Amazon UK)
Motherboard: MSI Z170-A PRO ATX LGA1151 Motherboard (£87.60 @ Amazon UK)
Total: £333.57
Generated by PCPartPicker 2016-12-30 14:58 GMT+0000
Does your £300 budget need to include RAM too, or will you be selling your DDR3 to pay for DDR4? Be aware that Intel's current processors and all future AMD CPUs use DDR4.
Cheers lad , I think I am gunna buy some HyperX fury ddr4 ram but is it necessary to upgrade from ddr3. Also I have chose to go for the i5 and the msi motherboard , thanks a lot :)
