Best CPU and RAM for Gaming and CAD?
cam1503
Commendable
Aug 27, 2016
With my own research i've found the i7 4790k to be the outstanding one for Gaming and CAD is there any better should i go down the AMD route?
Only thing is the 4790k only works with ddr3 motherboards, is ddr3 enough in this day and age for gaming and CAD?
AMD is not the way to go right now, compared to a 4790k. Your graphics card is more important for either gaming or CAD than the CPU once you have a quad core CPU.
You'll want to stick with Intel for CAD. While yes DDR4 memory can outperform DDR3, we're not at a point where that's going to seriously hamper your efforts unless you're using this as a professional rig. In which case you'd be wanting to look at an X99 system anyway. If you're building a system from scratch right now, theres not really a reason to not go with a Skylake over Haswell system. If you're looking to upgrade in a direction that allows you to continue to use existing DDR3 memory, stick to Intel. While AMD is cheaper, it doesn't preform as well for CAD applications.
