A AC-DC989 Honorable May 8, 2013 40 0 10,530 Feb 3, 2015 #1 I'm picking up an i5 4690k but I need a cooler that is good enough to allow overclocking. It can't be taller that 155mm and less than $60.
Solution Dark Lord of Tech Feb 3, 2015 CRYORIG H7 Tower Cooler For AMD/Intel CPU's http://www.newegg.com/Product/Product.aspx?Item=9SIA4UF2DZ6565&nm_mc=KNC-GoogleMKP-PC&cm_mmc=KNC-GoogleMKP-PC-_-pla-_-CPU+Fans+%26+Heatsinks-_-9SIA4UF2DZ6565&gclid=CIij5MqGxcMCFWxp7AodVWMAmg&gclsrc=aw.ds Dimension ( with fan ) L98 mm x W123 mm x H145 mm http://www.cryorig.com/h7.php
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Feb 3, 2015 Solution #2 CRYORIG H7 Tower Cooler For AMD/Intel CPU's http://www.newegg.com/Product/Product.aspx?Item=9SIA4UF2DZ6565&nm_mc=KNC-GoogleMKP-PC&cm_mmc=KNC-GoogleMKP-PC-_-pla-_-CPU+Fans+%26+Heatsinks-_-9SIA4UF2DZ6565&gclid=CIij5MqGxcMCFWxp7AodVWMAmg&gclsrc=aw.ds Dimension ( with fan ) L98 mm x W123 mm x H145 mm http://www.cryorig.com/h7.php Upvote 0 Downvote Solution
A AC-DC989 Honorable May 8, 2013 40 0 10,530 Feb 4, 2015 #3 Thanks but are there any more options? Just want a few to choose from Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,818 1,871 159,590 Feb 4, 2015 #4 With your height restrictions , there aren't to many options. Upvote 0 Downvote
A AC-DC989 Honorable May 8, 2013 40 0 10,530 Feb 4, 2015 #5 With your height restrictions , there aren't to many options. Alright, thanks! Upvote 0 Downvote
