Best CPU cooler for H440 case
KenAyugi
29
Hi I am building a PC using the NZXT H440 case & ASRock Extreme6 MB. I have been looking at the CoolerMaster Hyper 212 Evo & the Corsair H110 as potential coolers but the 212 Evo seems like it may obstruct some of my RAM slots (i am planning on filling all 4 slots). Any suggestions on the best cooler for that case/mobo combo? (Performance is priority)
Then the kraken x61 is your probably one of your best choices. According to benchmarks it can go 1-2 degrees cooler than the noctua d15 and you won't have a problem with your ram, and your case will fit it.
Yeah NH-D15 is a really good cooler i hear but i think it'll definitely block some RAM slots. Any thoughts on Kraken x61 or the be quiet dark pro (i'm not sure what its called)? I've seen a couple of those in use.
If the OP was worried about the 212 Evo covering the RAM slots, the NH-D15 will make them faint. Not that its a bad cooler, I love mine. But its a fricken beast.
First, while I have a place in my heart for the 212 Evo, there are better on the market that are shorter and dont cover the RAM slots. However, if the Evo is your thing, you can just adjust the fan up a few mm to adjust for the RAM. Without knowing which RAM you're using I cant say for sure how much clearance you need, but it should work ok with adjustment. You have up to 180mm in that case for CPU cooling so you'd be fine with the Evo.
However, like I said, there's better out there. Without knowing which Exteme6 you're going with I can give exact recommendations but these will fit in your case. For air cooling, look at the Cryorig series. The M9i is pretty much a direct replacement for the Evo, only no RAM slot overhang and a better looking mounting system. The H7 is a step up, same kind of mounting system as the Evo but a better cooler and again no RAM overhang. The H5 Universal is bigger still (getting closer to the NH-D15 size), but still no RAM overhang. H5 Ultimate is where you finally hit some RAM overhang but its adjustable for ram over 30-35mm in height. R1 series is where you start getting in to direct competitors for the NH-D15, and you'd need to check their compatibility chart for your motherboard. The Extreme series of boards tends to have very large VRM heatsinks so the really big air coolers may cause mounting problems. I've worked with the H7 and H5 series and love the heatsinks. I prefer the mounting system of the H5 over the H7 (and Evo) but they're all solid designs.
For water, the Corsair H110 is supposed to be solid, I've only played with the H80i and H100i. The Cooler Master Nepton tends to score well on the charts but I don't have any experience with them. I also like the Kraken X61. The Kraken doesn't always outshine Corsair or Cooler Masters Nepton series but install of the Kraken is so much easier than the Corsairs I've played with and its very quiet. The tubing is longer and more flexible. But that's just preference. The software on the Kraken is also less prone to problems than the Corsair i series, if you want something with some light up color to it. You can fit a 280mm (2x140mm) or 3x120mm up top, which will likely be your best option. Front mounting does exist but it always looked like a major hassle.
Hellz yeah! I bought an i5-4690k but feel terrible about not picking the i7-4790k which would suit me better (in my graphic design & such & such) so i am going to push that proc to its limits lol
Agreed, the Kraken X61 will probably give you the best bang. Install is pretty simple, and putting it in the H440 was pretty easy. Tho it doesn't hurt to check out the youtube howto's to help the process along. Any air cooler will have to be huge to compete and coming as an owner of one of those, the X61 is just a more elegant setup.
Cool. Thanks alot.
Ha! If i sell a kidney I'm getting a 5960X or dual Xeon. I'm gonna go super saiyan! 😀
PS: I'm jealous of your build.
I tend to go balls out when I do a build since I tend to wait 7-8 years between rebuilds and need something that can make Photoshop its bitch, but there are times I wish I had changed out a few things. The NH-D15 was the best option at the time but it severely limited my RAM options so I'm running stock DDR3 1600 instead of any overclocking fun. And of course a year after I built the X99 systems launched. But the Devils Canyon CPUs OC pretty well tho, so you should get some great speed out of yours with that Kraken.
