I would prefer air cooling, but I will consider liquid if the fan thingy will go on a 120mm fan mount on top of the case.
Case: http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119256
Ram: http://www.newegg.ca/Product/Product.aspx?Item=N82E16820104262 (tried to find some without giant het spreaders, feel free to recommend better stuff that will also fit with the cooler)
Motherboard: http://www.newegg.ca/Product/Product.aspx?Item=N82E16813132118
CPU: http://www.newegg.ca/Product/Product.aspx?Item=N82E16819117372
Power supply: http://www.newegg.ca/Product/Product.aspx?Item=N82E16817438017
