Best CPU cooler for i5-8600k and mATX
minimlbanalyst
Commendable
Dec 17, 2018
31
I am looking for a CPU cooler for my i5-8600k which I might overclock with in the future, but not extremely. It would be great if it was compatible with the mATX case NZXT H400i, which has a clearance of 164mm for the cooler, and I would like to have a little space for airflow.
If it will help, here is my PC build:https://pcpartpicker.com/list/P82wnH
Thank you so much for your help, I really appreciate it!
The Scythe coolers are good for the price though. See the test results compared to the NH-D15 (non-S).
https://www.tweaktown.com/reviews/8320/scythe-mugen-5-rev-cpu-cooler-review/index6.html
You can get a liquide cooler becouse of the CPU you have ( it is a good cpu which you want to keep cool)
A corsair one (240mm): https://pcpartpicker.com/product/hmBTwP/corsair-h100i-pro-750-cfm-liquid-cpu-cooler-cw-9060033-ww
(280mm):https://pcpartpicker.com/product/W6RzK8/corsair-h115i-pro-554-cfm-liquid-cpu-cooler-cw-9060032-ww
(280mm) but RGB and better:https://pcpartpicker.com/product/vTTPxr/corsair-h115i-rgb-platinum-970-cfm-liquid-cpu-cooler-cw-9060038-ww
A cooler master one (240mm): https://pcpartpicker.com/product/RcdFf7/cooler-master-masterliquid-ml240l-rgb-667-cfm-liquid-cpu-cooler-mlw-d24m-a20pc-r1
(280mm):https://pcpartpicker.com/product/n7H48d/cooler-master-masterliquid-pro-280-642-cfm-liquid-cpu-cooler-mly-d28m-a22mb-r1
A nzxt one (240mm):https://pcpartpicker.com/product/kTL7YJ/nzxt-kraken-x52-rev-2-731-cfm-liquid-cpu-cooler-rl-krx52-02
(280mm): https://pcpartpicker.com/product/2RdFf7/nzxt-kraken-x62-rev-2-982-cfm-liquid-cpu-cooler-rl-krx62-02
Thanks, I'm looking for an air cooler, but the Noctua NH-D15s looks cool. The fan with the brackets would fit inside my case? Also, sorry for not giving a budget, the Noctua one is fine, but could you look for a fan under $50? Thank you so much.
The NH-D15S will fit in your case, it only needs 160mm of clearance.
What do you mean a fan under $50?
I mean I have a budget of $50 for the cooler. Sorry if that was confusing, I am having a lot of trouble picking out a cooler, and you have been a great help.
Wow, thank you so much! I will think about your replies, they have helped a lot. Okay, one last question: If you were to choose, would it be the Cryorig H5 Universal or the Noctua NH-D15S?
Okay, just to confirm, the Cryorig H5 Universal would fit in my case with 164 mm of clearance, and it would be better than the Noctua NH-D15 because it would not interfere with the RAM? Thank you for your help!
