Best CPU cooler for i7 2600 ?
PK_6191
8
So I'm looking for a Cpu cooler for an i7 2600. But it has to fit in an iBall Rider cabinet.
Dimensions of the cabinet : 462(H) x 200(W) x 545(D) mm
Oh ! And the motherboard is an ASUS P8H67 M LX so I'm worried if going with the Cooler master Hyper 212X would block the PCI-e port where the graphic card goes or the RAM slots. Never bought an aftermarket cooler you see. HELP !
And heres the link of the website I'm planning to get one from :
http://www.snapdeal.com/search?keyword=cpu+cooler&santizedKeyword=&catId=&categoryId=&suggested=false&vertical=&noOfResults=20&clickSrc=go_header&lastKeyword=&prodCatId=&changeBackToAll=false&foundInAll=false&categoryIdSearched=&cityPageUrl=&url=&utmContent=&dealDetail=
Would be really helpful if you guys could suggest on from that^ website. And my budget is 1500 to 2000 Rs.
Thanks in advance.
I'm using the s40 on this board mate.
http://www.asrock.com/mb/Intel/H61M-DG3USB3/
Fairly compact like yours - the s40 doesn't block anything on mine at all.
You should be fine mate , its a decent little cooler - stress tested my 3470 & it never got above 50c under a prime test.
Impressive cooler for the money & very compact height wise
@Celtic_warrior99 Hyper 212x is a bit pricey for me. So I'm planning on going for the Deepcool Gammaxx S40. So Hyper 212x measures 120 x 79 x 158 mm and the gammaxx S40 measures 120 X 81.3 X 143mm. So I should have no problems yeah ?
@madmatt30 Deepcool S40 was on my shortlist ! Think its going to be my final choice. However it wont block any of the slots on the P8h67 m lx right ?
