Best CPU cooler for i7 3770k + Thermal Paste
SkyHawksGamers
82
Hey guys. I have had my PC for over two years, I have an i7 3770k @3.9GHz and I have never removed the stock cooler or updated the thermal paste (bad I know). But I now believe it is time to add a new cooler and possibly some new thermal paste?
I am currently looking at the Cooler Master Hyper 212 EVO as I've heard it has a great reputation. I am unsure about the thermal paste.
I have never changed the cooler or anything like it before; so there are three things I ask of you:
1) Which CPU cooler would you honestly recommend for my CPU in a reasonable budget range? (£20-£30)
2) Which thermal paste? (if the type honestly matters)
3) And I am sort of a noob to all of this, I have never done anything similar to this before; so is there anyway I could have a brief summary or a link to a useful video showing how to change the cooler AND apply thermal paste? Also I presume the stock cooler is 120mm (I haven't checked yet?) And I have looked at a few videos but none of them show the first part of the process (seemingly removing the motherboard/CPU from the PC?)
Thank you very much! Sorry to ask so much.
hyper 212 evo http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099&cm_re=hyper_212-_-35-103-099-_-Product OR
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&cm_re=hyper_212-_-35-103-065-_-Product 29.99
I'd recomend getting the latter it's a great after market cooler Hyper 212 Plus
I've heard good things about ic diamond, but artic silver 5 should do just fine plus it's half the price for what maybe a degree of a difference.
http://www.amazon.com/gp/product/B000OGX5AM/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=1944687542&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B0042IEVD8&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0H5QYJ943SKCMY4JTQKV
You're not gonna find a much better price v performance after market cooler then the Hyper 212 Plus
Thank you for the replies guys. I think I am going to go with the Hyper 212 EVO (regular one) that I said originally. Only two more things now:
-Do you know if the stock fan for the i7 3770k is 120mm?
and
-I am sort of a noob to all of this, I have never done anything similar to this before; so is there anyway I could have a brief summary or a link to a useful video showing how to change the cooler AND apply thermal paste? I have looked at a few videos but none of them show the first part of the process (seemingly removing the motherboard/CPU from the PC?)
Thanks! :)
