Best CPU Cooler for my config
Vins_IT
Hi guys, I need some help to get a CPU cooler.
My config is:
Mobo: ASUS P8Z77-V
CPU: Intel Core i7-3770 @3,9GHz
RAM: Corsair Vengeance 4x8GB @1866MHz (I overclocked it to 2133MHz and it's pretty stable)
GPU: Sapphire R9 280X Toxic
Case: Aerocool GT-A
With the stock cooler i reach also 80/90C°, and last time, I was playing GTA V, my PC gave me a red screen, and when i booted it again, it said me "CPU Over Temperature erorr".
So, i basically need to change my CPU cooler, but I need one that supports my High Profile Vengeance, too.
I think it's not a case problem, as my GPU reaches max 80C° while playing in 1440p and Ultra settings.
I agree, the Cooler MAster Hyper 212 Evo is the most cost effective soulution to lower your cpu temps. Considering that your cpu is locked, it will do just fine. of course if you want maximum cooling performance you can go for a high end air cpu cooler like Noctua NH-D14 or NH-D15 (I don't think they will fit with the case closed.). Another possible choice is Noctua NH-U12S, or a closed loop AIO water cooler like Corsair H110i or something similar.
