best cpu cooler for my fx 8320
anirban130
18
dear guys,
my fx 8320 gets upto 80 deg in nearly 10mins of playing NFS Rivals, amd abve that it shutsoff the whole computer.
i have cooler master K380 cabinet with one 120mm cabinet cooling fan.
WHat i need to do to play for longer hours? pls help
I recommend getting an Arctic Cooling Freezer 7 Rev 2 heat sink fan. It's nice and quiet and should reduce the temperature by a significant amount.
If you have a a higher budget then you may want to consider water cooling. The Corsair H55 is a great water cooler and not too expensive.
Other things to consider maybe to get some better thermal paste or buying a few more case fans. Also, adjusting your Bios settings may help.
Yes it is installed properly, i play other games such as crysis 3, blacklist and sniper ghost warrior 2 without any problem. but still the temp is around 70 deg.
I am using Corsair VS550 Watt PSU with Asrock 970 extreme 4, As per my budjet i am thinking to get CM hyper 212 Evo and artictic silver 5 as thermal paste.
Will My PSU be sufficient if i gp as per ur Suggestion, i have already order 3 120mm cabinet fans and its on the way.
ya i m also thinking to have this, but my question is will i be able to play long enough continously for 5-6hrs with this CM hyper 212 evo?
i m also planning to get arctic silver 5 as thermal paste... what u think?
but actually tomshardware forum said it supports and supports good... 🙁
what should be the bios version? when i get home, will tell u
and my hardware monitor says that it goes to around 3995mgz max and min t0 1995mgz... isit ok? min temp goes to 18 deg and max 75-80 deg..
and what should be the best motherboard for my fx 8320 at budget around the asrock 970 extreme 4?
yes I just updated my bios from p2.50 to p 2.60.
As a matter of fact, I think my temperature got stable but still its touches 70 n comes below 70 also while playing.
but on ideal booting, I m getting cpu temp 40 deg, but my all cores are at 28 deg. this is shown by AIDA64 software.
So whats my actual temp?
what should I do in the bios of asrock 970 extreme 4?
HEy buddy,
is all model of cooler master hyper 212 evo same? i mean RR-212E- 20PK R2 and RR-212E-16PK-R1?
WHICH ONE WILL BE GOOD FOR MY FX8320 ON ASROCK 970 EXTREME 4?
but i already ordered it.. will there be any problem if i install it?
I have a 8320 on a M5A97 EVO non OC with stock cooler and mine goes around 65 degree. I would say that 70 should be healthy, that is the best that you could get with a stock cooler
how many case fans do you have?
Right now i have just one 120mm fan that came as factory fitted with my cooler master cabinet, but 3 fan i have already ordered, i will get it by next 3-4 days.
So what u suggest me to do, i mean where should i put my 3 fans in the cabinet... i have two slots at the top, one side, one bottom and two rear.. the one i ordered is also 120mm of cooler master
Right now only one have , the stock fan from cooler master.. already ordered three... after disabling the auto overclock option from bios, its now fixed at 3500mhz, idle 36 deg and on hoyrs of playing it goes to 63-67 deg... i want to make my processor more chill with aftermarket evo cooler for future proof and protection. Am i thinking rite?
I have 3 case fans, one intake and two exhaust, and there are loads of holes where cool air can come in.
I have 22c idle, and 65 100% load ( at gaming its lower, around 50-55 max)
First I would add several fans to the case and see if they make a difference, they should
what case do you have?
i have cooler master KD380 cabinet.
