[SOLVED] Best cpu for 300 euro on h110m dgs
Dark Lord of Tech
темный лорд технологий
125,500
1,029
167,040
24,735
Dark Lord of Tech
125,500
1,029
167,040
24,735
If the BIOS is updated and if it's the K you would need a cooler.
Dec 31, 2018
40
okay last question im checking the difference between i7 6700k and i5 9600k and thinking about buying other motherboard is it worth or should i go with the i7 6700k?
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor (€158.89 @ Mindfactory)
Motherboard: ASRock - B450M PRO4 Micro ATX AM4 Motherboard (€83.52 @ Mindfactory)
Total: €242.41
Generated by PCPartPicker 2019-01-01 19:38 CET+0100
I'd be more inclined to do the above & sell your current cpu & board.
Youll be better off money wise, performance wise, & upgradability wise.
Skylake cpu prices are obscene compared to both Intel & amd current gen cpu's
