Plz someone help me
i am confused about which processor is best for gaming, under 12000 INR
also i am confused which company processor is Fast, Durable and reliable
AMD or Intel???
Plz help me
which processor to choose between AMD and Intel???
If you want something that lasts longer, you're better off with the Intel Core i5 over an AMD FX. As the FX series processors are already 3 years old with no foreseeable change coming, and they are based off a horrible (Bulldozer/Piledriver) Architecture, these days. It's best to stick with Intel.
Well the MoBo will depend if you want SLI ability or not. Any B85 or H81 or H87/97 MoBo from Gigabyte/ MSI/ Asus/ Asrock would be good for the CPU. So it depends on the fact if you want SLI ability or not.
For FX 6, its not comparable to i5 in performance, but rather i3, so we can eliminate that.
