R Radijuska Commendable Apr 3, 2017 15 0 1,510 Apr 3, 2017 #1 Hi, I have 1050 Ti G1 GPU and i want to ask what is best solution CPU for this GPU. Thanks.
Solution st3v30 Apr 3, 2017 Hope this helps you. https://www.youtube.com/watch?v=Cyf7OKZNq0M Your g3240 runs at 3.1 Ghz so it is even bigger difference in games. Also there is this video it shows how well G4560 stacks with other CPU's when using low to high end GPU's. https://www.youtube.com/watch?v=FUapuF0y30s
rcald2000 Splendid Nov 3, 2009 5,609 164 28,990 Apr 3, 2017 #2 Intel Pentium G4560 combined with a B250 chipset motherboard is a good match. This CPU currently sells on NewEgg for $65 and is very close to the gaming performance of the Core i3-7100. Upvote 1 Downvote
why_wolf Splendid Aug 28, 2015 3,651 196 27,090 Apr 3, 2017 #3 Agreed G4560 would be best CPU for that GPU. Upvote 0 Downvote
R Radijuska Commendable Apr 3, 2017 15 0 1,510 Apr 3, 2017 #4 lol i have now G3240 so its not a big differnce Upvote 0 Downvote
st3v30 Admirable Nov 1, 2014 1,920 1 6,460 Apr 3, 2017 Solution #5 Hope this helps you. https://www.youtube.com/watch?v=Cyf7OKZNq0M Your g3240 runs at 3.1 Ghz so it is even bigger difference in games. Also there is this video it shows how well G4560 stacks with other CPU's when using low to high end GPU's. https://www.youtube.com/watch?v=FUapuF0y30s Upvote 0 Downvote Solution
rcald2000 Splendid Nov 3, 2009 5,609 164 28,990 Apr 15, 2017 #6 +Radijuska I respectfully disagree. There is an appreciable difference between a G3240 vs G4560. The latter is a dual core hyper-threaded CPU. http://cpu.userbenchmark.com/Compare/Intel-Pentium-G3240-vs-Intel-Pentium-G4560/2820vs3892 Upvote 0 Downvote
