Question Best cpu for PGA478?
Matoo69
519
15
18,995
So i have laptop with pga478 (P Socket)
chipset (Intel GM45/GM47 rev.07)
Now i have t4300 and i am planing to buy t9300
what cpu is the best you think? To buy?
What max ram i can have for this and best CPU (and are the t9300 good upgrade)
thanks
Socket 478 and P are not the same socket and are not compatible with each other. You do have socket P but just because it's the same socket, does not mean the bios is compatible. It's a waste of time and money and it's not worth it. Nothing you can change will make much of a difference at all. If it's just to tinker than go ahead.
Ok thanks,i think intel gm45 as i search support 8gb ram i try to find cheap 4gb ddr2 but i cant... 1x4gb ddr2 hard to find and if you find is like 50/60€ thats to much..
i will put 2x2gb to have 4gb and 120gb ssd + new cpu if i can,but i search for cpu and i can becose cpu is not soldred and some people say that they upgrade but i need secend opinion
No is not its like 120gb ssd 35$ and 500gb ssd almost 100$ i order from ebay all staf i order 3times for 775socket,1155 and i think was am4 and all the time was all good and working :)
btw i pay 120gb ssd on ebay 23$
You're paying too much on ebay for junk. You can get brand new name brand stuff for that much. Used stuff on ebay should be at least 1/2 the cost of new.
I paid $7 for a 120GB ssd almost a year ago. 😉
