I am in search of a CPU for my streaming PC that will work alongside my gaming PC to deliver the highest quality stream possible without any 'Taking too long to encode' issues. I am hoping to stream with AT LEAST these settings in OBS:
>VIDEO ENCODING
Encoder: x264
Use CBR: False
Enable CRB padding: True
Quality Balance: 10
Use Custom Buffer Size: True
Max Bitrate (kb/s): 3500
Buffer Size (kbit): 3500
>AUDIO ENCODING
Codec: AAC
Bitrate: 160
Format: 48kHz
Channel: stereo
>VIDEO
Resolution Downscale: None (1920x1080)
FPS: 60
>ADVANCED
x264 CPU Preset: Slower
I'd like to spend the least amount possible, AMD or Intel.
>VIDEO ENCODING
Encoder: x264
Use CBR: False
Quality Balance: 10
>AUDIO ENCODING
Codec: AAC
Bitrate: 160
Format: 48kHz
Channel: stereo
>VIDEO
FPS: 60
>ADVANCED
