Best cpu water cooler to fit my case
Niruvius
137
Hi im looking for best watercooler that can fit nzxt s340 with sapphire nitro r9 390 inside.
Need to work with 1151 socket.
Prefer cpu cooler that is reasonably cheap (i know 40-50$ dont offer great watercooling units but i dont want to spend more than 100-125$
miggtt699
CPU Cooler: Cooler Master Seidon 240M 86.2 CFM Liquid CPU Cooler ($64.99 @ Newegg)
CPU Cooler: Cooler Master Glacer 240L 86.2 CFM Liquid CPU Cooler ($99.98 @ OutletPC)
CPU Cooler: Corsair H105 73.0 CFM Liquid CPU Cooler ($101.19 @ Amazon)
CPU Cooler: RAIJINTEK TRITON GREEN 100.5 CFM Sleeve Bearing Liquid CPU Cooler ($94.99 @ Newegg)
CPU Cooler: Cooler Master Nepton 240M 76.0 CFM Liquid CPU Cooler ($99.99 @ Newegg)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler ($109.99 @ Amazon)
CPU Cooler: Cooler Master Glacer 240L Ver. 2 86.2 CFM Liquid CPU Cooler ($99.99 @ Newegg)
CPU Cooler: Enermax Liqmax II 240 96.0 CFM Liquid CPU Cooler ($88.24 @ Amazon)
These are great options for your build.
You'll have to mount the radiator on the front of the case, and for optimal airflow, use the fans that come with the cooler, the case fans aren't that great for air pressure most of the time.
Woody1999
Admirable
Any water cooler up to 280mm will fit in the front of the S340. As far as I know, the only ones that people have been having problems with is the H105 and H110.
As you don't want to spend much, I recommend something like the Kraken X41 or CM Seidon 120XL. You can mount this in the back exhaust and use the two included fans as intakes in the front.
Woody
