Hi guys & gals,
My parents current netgear DGN3300 (ADSL modem/router combo) range is no longer proving to be adequate (Could be reduced Tx power due to neighbours interference). I'm very comfortable with networks (I run my own custom router on Ubuntu at my place), however I'm not so up to date with current equipment.
I was wondering if anyone can recommend a good Wireless AC Router, preferably an ADSL router combo (I know the choice is limited), or if the only great options are cable routers then can anyone recommend a good ADSL modem & cable routers? I only ask because the modem (the ISP provided) throughput is substantially lower than the netgear combo this was tested with by wire FYI.
Currently our router (2.4Ghz & 5Ghz) is in one corner of the house (all our network plugs go to this room & one of the few with a phone socket)
I plan on placing the new router in the current position with 5g (ground floor study) for working areas that want high speed access (mainly time machine backups), and the old router as an access point on the extreme opposite side of the house (loft - above the 1st floor) on 2.4Ghz to provide access to bedrooms/2nd living room.
Budget is ~£130, high range & 802.11ac is preferable.
Any suggestions on the proposed setup will also be greatly appreciated (the loft spans the whole house and there is a wire up there so very flexible on position).
Thanks,
Alex
Thanks,
Alex
