Going to build a completely new pc for Intel Coffee Lake with this case :: https://www.newegg.com/Product/Product.aspx?Item=N82E16811133327&ignorebbr=1
First time I'm going into custom water cooling loops and I have no idea what parts are good and not. I need a decent Waterblock that supports an LGA 1151 socket; might be going with this: https://www.newegg.com/Product/Product.aspx?Item=9SIAAXT4PR3677&ignorebbr=1&nm_mc=KNC-GoogleMKP-PC&cm_mmc=KNC-GoogleMKP-PC-_-pla-_-Liquid+%2F+Water+Cooling-_-9SIAAXT4PR3677&gclid=Cj0KCQjw6NjNBRDKARIsAFn3NMqgyoZTR8jl_ChHy8DiJDw9go37CDOYsI-_FeD03xhDxAbHBH-plgkaAlGZEALw_wcB&gclsrc=aw.ds
Not sure what pipes to use, preferably hard pipes. Planning on bending them myself, I'll figure that out later as I go. Also not sure what radiator, pump, or reservoir to use. Already bought 6 Noctua fans for the build so far.
Sorry if I gave you nothing to work with, but thanks in advanced
