Best dremel bit for cutting small holes in thin sheet metal
JulieLM
Hello,
I'm hoping someone can give me some help with this. I'm an artist making custom art lamps. I purchased 36 gauge copper foil/sheet metal. I want to cut small holes all over it so the lamps cast light on walls/ceilings. The holes need to be smallish (between 1/8" and 1/4" diameter). I have a dremel with a ton of bits, but want to use the correct one. Best bit for this particular job?
THANKS!! :??:
