Hi, I use my laptop in a room that is "far" away from the modem. It's like 20-25 meters, and there are walls between the laptop and the modem. The ONLY solution is buy a better WiFi card that has an amazing range and can reach nice speeds (2 MB/s or faster). So please, don't offer me any other product, I'm looking just for WiFi USB adapters.
With my laptop's internal WiFi card, an Intel-N 7260, I can sometimes connect to my modem, but speed is ridiculously slow, like 20KB/s, and the signal is very poor all the time. Very unstable.
Months ago I bought a high-gain TP-Link WN822N USB adapter:
Using that adapter, I can connect to my modem 80% of the time, and I reach usually 100-300KB/s, that is not bad, but still not enough, mainly because sometimes the signal is so poor that it disconnects from the modem.
http://www.tp-link.com/lk/products/details/?model=TL-WN822N#spec
This adapter has dual 3dBi omni directional antennas, it's N, Transmit power <20dBm(EIRP), and these numbers:
270M: -68dBm@10% PER
130M: -68dBm@10% PER
108M: -68dBm@10% PER
54M: -68dBm@10% PER
11M: -85dBm@8% PER
6M: -88dBm@10% PER
1M: -90dBm@8% PER
I'm looking for a considerably better adapter, with better specs so I can connect to my modem and navigate without problems most of the time. The problem is that I don't know much about all these WiFi specs, I don't know when companies "lie" about numbers, I don't even know what exactly mean all those numbers.
Could you guys recommend me a better WiFi card under $40?
Keep in mind I'm trying to establish a connection from 25m, and there are walls, so I need long range WiFi USB adapters. I wouldn't like to have an ultra large 10dBi antenna, I prefer compact and small designs, if possible. Indeed, one friend of mine lend me a 5dBi antenna WiFi card adapter and the connection was WORSE than when I use my dual 3 dBi adapter.
THANKS!
54M: -68dBm@10% PER
11M: -85dBm@8% PER
6M: -88dBm@10% PER
1M: -90dBm@8% PER
THANKS!
