T TheLoneWolf989 Honorable May 10, 2013 85 0 10,630 Jun 4, 2014 #1 As the title says, what is the best fan controller?
Solution Eduello Jun 4, 2014 NZXT Sentry 2: http://www.amazon.co.uk/NZXT-SENTRY-Touch-Screen-Controller/dp/B002L16OMO
T TheLoneWolf989 Honorable May 10, 2013 85 0 10,630 Jun 4, 2014 #3 Eduello : Budget? About £30 Upvote 0 Downvote
mickypheonix Honorable Mar 9, 2014 4,072 1 10,960 Jun 4, 2014 #4 Hi TheLoneWolf989 I have one of these , Sunbeamtech Rheosmart 6 Fan Controller , been using it now for 3 years , has pwm fuction , best investment i made for a fan controller , it controlls 6 fans in a hafx case , very responsive and smooth , still good as the day i bought it , never had an issue http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=Sunbeamtech+Rheosmart+6+Fan+Controller&N=-1&isNodeId=1 http://www.amazon.com/Sunbeamtech-PL-RS-6-Rheosmart-Fan-Controller/dp/B004LKZESI Upvote 0 Downvote
T TheLoneWolf989 Honorable May 10, 2013 85 0 10,630 Jun 4, 2014 #5 mickypheonix : Hi TheLoneWolf989 I have one of these , Sunbeamtech Rheosmart 6 Fan Controller , been using it now for 3 years , has pwm fuction , best investment i made for a fan controller , it controlls 6 fans in a hafx case , very responsive and smooth , still good as the day i bought it , never had an issue http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=Sunbeamtech+Rheosmart+6+Fan+Controller&N=-1&isNodeId=1 http://www.amazon.com/Sunbeamtech-PL-RS-6-Rheosmart-Fan-Controller/dp/B004LKZESI Can't find it in the UK. Upvote 0 Downvote
Eduello Judicious Mar 2, 2014 9,075 0 32,960 Jun 4, 2014 Solution #6 NZXT Sentry 2: http://www.amazon.co.uk/NZXT-SENTRY-Touch-Screen-Controller/dp/B002L16OMO Upvote 0 Downvote Solution
mickypheonix Honorable Mar 9, 2014 4,072 1 10,960 Jun 4, 2014 #7 found one for you http://www.kustompcs.co.uk/acatalog/info_28060.html Upvote 0 Downvote
