PC Specs
Mobo: MSI Z790 Gaming Plus WiFi
CPU: i7-14700k
GPU: RTX 4070
RAM: 32GB
OS: Windows 11
I just installed the Arctic Freezer 3 Liquid 360. When I first started it, the pump made some bubbling noises, but they disappeared. However, there's still a slight whining noise coming from the pump. Is that normal?
I also set all the fans in the BIOS to PWM mode, including the system fans, and configured the fan curve to Smart Control. Is this a good setup, or is there a better way to adjust the fan curve?
For now, I connected the All-in-One (AIO) cable, which controls everything. Any suggestions for improvement?
CPU: i7-14700k
GPU: RTX 4070
RAM: 32GB
OS: Windows 11
