Question best fans for Lian Li 011 Dynamic
Jul 29, 2019
7
Hey guys, so i just build my first pc i got :
  • lian LI 011 dynamic
  • Ryzen 3700x with aircooler ( wraith prism )
  • 5700 xt radeon with a blower
So my question is what would be the best fans , i understand intake and exhaust but im kinda lost if i should use air flow fans or static pressure one because ppl say static pressure are the best against rads, dust filter
and since they are 3 dust filter , should i use 9 static pressure fans ?
So any suggestion ?
Thanks !
Have you built your system?
I'm actually looking at the Lian Li Dynamic as my next PC case... and the same as you regarding airflow, this is how I'm going to set it up:
3x intake from side (static flow) for the radiator (max 1000 rpm)
3x intake high pressure for the bottom (max 1000 rpm)
3x low noise/'normal' fans to the exhaust (max 800 rpm)
See how the positive / negative pressure is...
