Best gaming graphics card for a 500w power supply under $120?
johnstilwell22
105
Power supply- CORSAIR CXM500M 500W
Processor- Intel Pentium E5400
Not sure if you need any more information than that, if you do ill tell you.
If there is a graphics card out there that can run black ops 2 at medium to high settings for this price please let me know! If there is none for that price maybe one that can run minecraft with shaders at max settings over 100 fps.
p_nut_uk
591
74
A R9 270X can be had for 160,quite and improvement over a 750ti, probably worth about 20fps in something like far cry 3. I wouldn't go any higher than that because you'll reach the limit of your cpu
johnstilwell22
105
What is the exact name and brand of that graphics card?
johnstilwell22
105
actually this one is different, this is the 270 and the other was the 270x
9ballfreak
103
7
It is different but if you want to stay below your budget its not much of a difference honestly the difference is minimal and doesn't need dual power connector's
Similar threads
