I personally don't think that you're going to get anything decent for under $40.
Personally I'd save up for something like a Steelseries Rival 300, which is $60.
I've been using a Corsair Harpoon for a while, and it's been good to me. The DPI is comfortable (I put mine at 3500) and it fits nicely in hand. A bit on the light side for me, but not a deal breaker. $30 on Amazon.
Thanks mate. Can you please give me some good reference for that?
A guy mentioned above Steelseries Rival 100, do you think that will work?
Sure thing. Here you go, a reliable source along with multiple options.
https://www.shopbot.com.au/pp-logitech-g402-hyperion-fury-fps-gaming-mouse-price-491203.html
Currently I am using Logitech G300S. It is going good but can anyone suggest me a better mouse within my budget?
Hi there, I am currently using CombatWing 4800DPI Programmable Gaming Mouse and i got it for $39. Price has probably gone down a bit since then. As far as the mouse is concerned, its absolute bliss playingn FPS on it. Its smooth and sturdy, all that you ever need in a mouse really!
